Salta al contenuto principale
Samsung Galaxy Tab A 9.7 Rear Camera Replacement
Cosa ti serve
  1. Samsung Galaxy Tab A 9.7 Rear Camera Replacement, Rear Camera: passo 1, immagine 1 di 1
    • Pry along the edge of the Samsung Galaxy Tab A 9.7 with an iFixit opening tool.
  2. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: passo 2, immagine 1 di 1
    • Insert a second iFixit opening tool along the edge and begin to pry open the back cover a little with each one.
  3. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: passo 3, immagine 1 di 1
    • Remove one of the iFixit opening tools and begin to go around the device with the other one until the back cover pops off.
  4. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: passo 4, immagine 1 di 2 Samsung Galaxy Tab A 9.7 Rear Camera Replacement: passo 4, immagine 2 di 2
    • Remove five 2.8 mm screws using the Phillips #000 screwdriver.
  5. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: passo 5, immagine 1 di 2 Samsung Galaxy Tab A 9.7 Rear Camera Replacement: passo 5, immagine 2 di 2
    • Disconnect all wires and strips that connect the motherboard to any other part of the device with an iFixit opening tool.
    • Lift up gently on all wires and strips.
  6. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: passo 6, immagine 1 di 1
    • Lift the motherboard out of the back panel using an iFixit opening tool.
    • Be gentle when wiggling the motherboard out from underneath the battery's protective edge.
  7. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: passo 7, immagine 1 di 1
    • Pull off the rear camera on the back of the motherboard and replace.
Conclusione
IUPUI, Team S1-G3, Hovde Spring 2019 Membro di IUPUI, Team S1-G3, Hovde Spring 2019
IUPUI-HOVDE-S19S1G3
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 279
