Salta al contenuto principale
Samsung Galaxy Tab A 9.7 Display Replacement
Cosa ti serve
  1. Samsung Galaxy Tab A 9.7 Display Replacement, Back Cover: passo 1, immagine 1 di 1
    • Insert a metal spudger between the back case and the screen of the device.
    • The back cover is attached to the device by a series of snaps. The snaps are positioned about an inch from each other.
    • Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
    • There will be an audible click every time a snap releases.
  2. Samsung Galaxy Tab A 9.7 Display Replacement, Battery: passo 2, immagine 1 di 2 Samsung Galaxy Tab A 9.7 Display Replacement, Battery: passo 2, immagine 2 di 2
    • Remove the eleven #000 Phillips 2.8mm screws that hold the battery in place.
  3. Samsung Galaxy Tab A 9.7 Display Replacement: passo 3, immagine 1 di 2 Samsung Galaxy Tab A 9.7 Display Replacement: passo 3, immagine 2 di 2
    • Place one hand on the battery and grasp the outer edge of the device with the other hand.
    • Flip the device over so that the battery falls over and onto your hand.
  4. Samsung Galaxy Tab A 9.7 Display Replacement: passo 4, immagine 1 di 2 Samsung Galaxy Tab A 9.7 Display Replacement: passo 4, immagine 2 di 2
    • Pull the battery out until it is only connected to the device by the black, yellow, and red connectors.
  5. Samsung Galaxy Tab A 9.7 Display Replacement: passo 5, immagine 1 di 2 Samsung Galaxy Tab A 9.7 Display Replacement: passo 5, immagine 2 di 2
    • Hold the battery and grip the wires with your thumb and finger.
    • Pull the wires away from the device to remove the white connector from the black socket.
    • Lift the battery away from the device.
  6. Samsung Galaxy Tab A 9.7 Display Replacement, Display: passo 6, immagine 1 di 1
    • Gently remove the tape covering the screen ribbon cable, located at the top of the devise.
    • With the plastic spudger, disconnect the ribbon cable from the motherboard, located at the middle of the device.
  7. Samsung Galaxy Tab A 9.7 Display Replacement: passo 7, immagine 1 di 1
    • Using a plastic spudger, work around the edge of the screen, prying the screen away from the device.
  8. Samsung Galaxy Tab A 9.7 Display Replacement: passo 8, immagine 1 di 1
    • Use the left side of the tablet as a hinge to swing the display assembly open.
    • As you move the display assembly, make sure that the display ribbon cable is unattached.
Conclusione
Altre 3 persone hanno completato questa guida.
1Commento della guida
my device burnt down.
HetBesteNaam - Replica Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 30
Tutti i Tempi: 3,399
