Salta al contenuto principale
Samsung Galaxy Tab A 7.0" Headphone Jack Replacement
Cosa ti serve
  1. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement, Headphone Jack: passo 1, immagine 1 di 1
    • Using the plastic opening tool, starting at any corner on the tablet, insert the tool between the back panel and the front panel.
    • Slide tool around the tablet to unlock the panels from one another.
  2. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: passo 2, immagine 1 di 2 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: passo 2, immagine 2 di 2
    • Carefully remove the back panel from the front panel.
    • The inner components of the tablet will now be exposed.
  3. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: passo 3, immagine 1 di 3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: passo 3, immagine 2 di 3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: passo 3, immagine 3 di 3
    • Remove the two Phillips head screws attaching the auxiliary port to the plastic frame using a P000 screwdriver.
    • Remove the four Phillips head screws attaching the motherboard to the plastic case using a P000 screwdriver.
  4. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: passo 4, immagine 1 di 1
    • Using tweezers disconnect the headphone jack connector from the motherboard.
  5. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: passo 5, immagine 1 di 3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: passo 5, immagine 2 di 3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: passo 5, immagine 3 di 3
    • Using tweezers, carefully lift up the motherboard.
    • Using tweezers, remove the metal jacket holding the headphone jack in place by grabbing the left corner where there is a recess to grab it.
    • There is a light adhesive holding the metal jacket down. You may have to pull slightly harder to get this off.
  6. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: passo 6, immagine 1 di 1
    • Remove the auxiliary port from the case.
Conclusione
Altre 5 persone hanno completato questa guida.
Bradley Watson
Membro da: 02/15/17
1.052 Reputazione
4 Guide realizzate
USF Tampa, Team 5-4, Passmore Spring 2017 Membro di USF Tampa, Team 5-4, Passmore Spring 2017
USFT-PASSMORE-S17S5G4
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 43
Tutti i Tempi: 3,588
