Salta al contenuto principale
Samsung Galaxy Tab A 7.0 Front Facing Camera Replacement
Cosa ti serve
  1. Samsung Galaxy Tab A 7.0 Front Facing Camera Replacement, Front Facing Camera: passo 1, immagine 1 di 1
    • Using the plastic opening tool, starting at any corner on the tablet, insert the tool between the back panel and the front panel.
    • Slide tool around the tablet to unlock the panels from one another.
  2. Samsung Galaxy Tab A 7.0 Front Facing Camera Replacement: passo 2, immagine 1 di 2 Samsung Galaxy Tab A 7.0 Front Facing Camera Replacement: passo 2, immagine 2 di 2
    • Carefully remove the back panel from the front panel.
    • The inner components of the tablet will now be exposed.
  3. Samsung Galaxy Tab A 7.0 Front Facing Camera Replacement: passo 3, immagine 1 di 3 Samsung Galaxy Tab A 7.0 Front Facing Camera Replacement: passo 3, immagine 2 di 3 Samsung Galaxy Tab A 7.0 Front Facing Camera Replacement: passo 3, immagine 3 di 3
    • Using tweezers, at the end of the gold wire, gently lift the black tab locking the wire connecting the camera to the motherboard.
    • Pull the wire from the connector, disconnecting the camera from the device entirely.
Conclusione
Altre 3 persone hanno completato questa guida.
Bradley Watson
Membro da: 02/15/17
1.052 Reputazione
4 Guide realizzate
USF Tampa, Team 5-4, Passmore Spring 2017 Membro di USF Tampa, Team 5-4, Passmore Spring 2017
USFT-PASSMORE-S17S5G4
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 41
Tutti i Tempi: 2,152
