Salta al contenuto principale
Sostituzione batteria Samsung Galaxy Tab A 10.1
Cosa ti serve
Panoramica Video
  1. Sostituzione batteria Samsung Galaxy Tab A 10.1, Copertura posteriore: passo 1, immagine 1 di 2 Sostituzione batteria Samsung Galaxy Tab A 10.1, Copertura posteriore: passo 1, immagine 2 di 2
    • Appoggia il dispositivo con lo schermo rivolto verso l'alto.
    • Inizia vicino ad uno dei bordi curvi del dispositivo(usa la seconda immagine come esempio).
    • Infila uno strumento di apertura in plastica tra la copertura posteriore e quella anteriore.
    • Se uno strumento di apertura in plastica non funziona, prova con uno spudger in metallo, ma potresti danneggiare la plastica sul dispositivo.
    • Ricordati di rimuovere la scheda micro SD (se inserita) prima di iniziare.
    AWESOME!! I was trying to open it from the “NOT OK” place and you saved me to broken the screen… thanks!!
    David Leiva - Replica
    No problem, enjoy.
    Roger L. Ortiz -
    Felt it was easier for me to do it from the middles out.
    Tanin Garcia - Replica
    @rogerlortiz You two seem to be miscommunicating. The author points out the location between the digitizer and frame in which to place a tool. While @Tanin Garcia, whom no longer seems to be member, was pointing out where along the edge from corner to corner it was best to start the separating process.
    B. A. Computer Services -
    Important: the display is sourrounded with a plastic frame. You need to get beween this frame an the backcover (not directly at glass edge as I tried it first and almost broke the glass). Get a closeup picture of it to clarify.
    Oliver Dawid - Replica
    wer lesen kann, ist klar im Vorteil - ich hab die SD-Karte drin gelassen. Hat aber funktioniert…
    Thomas Wolter - Replica
    Don’t use a very small flathead screwdriver as a spudger. Just shattered the screen :(
    nikvoss - Replica
    Yes, shattered the screen. To the garbage, it goes. A little knowledge is a dangerous thing. This a repair better suited for a professional repair! Thanks for helping me make the decision to get another one!
    vancega - Replica
  2. Sostituzione batteria Samsung Galaxy Tab A 10.1: passo 2, immagine 1 di 2 Sostituzione batteria Samsung Galaxy Tab A 10.1: passo 2, immagine 2 di 2
    • Una volta che lo strumento di apertura in plastica è stato infilato, usalo per fare leva lungo i bordi del dispositivo per separare la copertura posteriore.
    • Rimuovi la copertura posteriore dal dispositivo.
    • La copertura posteriore emetterà qualche crepitio mentre viene rimossa dal dispositivo.
  3. Sostituzione batteria Samsung Galaxy Tab A 10.1, Scollega la batteria: passo 3, immagine 1 di 1
    • Rimuovi la protezione adesiva e ruota verso l'alto l'aletta di bloccaggio sul connettore ZIF della batteria.
    • Sfila il cavo a nastro arancio della batteria dalla sua presa.
    BEWARE!!! later on Samsung tablets the tab holding the main cable (marked “MAIN”) breaks as soon as you attempt to lift the tab to remove the ribbon! I reckon Samsung designed this breakabloe tab to not only avoid the warranty, but the render the tablet useless!
    graham chapman - Replica
    Happened to me also, in order to replace that broken tab, do you think it will be necessary to replace the motherboard? I highly doubt we can find the parts to fix (replace) the flip-tab.
    jeanuhlik -
    I also had this problem, the connector broke, even if i was very careful, i still can use the tablet, i pushed the “main” cable in place and used a little bit of hotmelt glue to hold it in place.
    Yannick - Replica
    I tried using aluminum foil to make the connection but it didn’t help at all, how did you attach it with the glue gun???
    jeanuhlik - Replica
    LOOK what I found!!! its the replacement for the connector we broke!!!https://www.parts4repair.com/samsung-gal...
    jeanuhlik - Replica
    i just wonder how u gonna solder this tiny thingie
    Mike Muley -
    I wish I had read this thread before I removed the cable and broke the connector. Unfortunately I have not been able to reattach the cable and my tablet is dead.
    If there is no way to remove this cable, why is this fix even posted here? I find this exceptionally uncool!
    Derek N. Eder - Replica
    Whoever broke the connector was trying to open it the wrong way. I have oil spilled in mine after I replaced my screen and digitizer together if you only replace the screen it is more difficult. I say changing both together is simpler. And I will share a pic either way I just might mess up MY connector. To be continued
    909 - Replica
  4. Sostituzione batteria Samsung Galaxy Tab A 10.1: passo 4, immagine 1 di 2 Sostituzione batteria Samsung Galaxy Tab A 10.1: passo 4, immagine 2 di 2
    • Rimuovi la protezione adesiva, solleva l'aletta di bloccaggio e sfila il cavo a nastro bianco dello speaker dalla sua presa.
  5. Sostituzione batteria Samsung Galaxy Tab A 10.1: passo 5, immagine 1 di 3 Sostituzione batteria Samsung Galaxy Tab A 10.1: passo 5, immagine 2 di 3 Sostituzione batteria Samsung Galaxy Tab A 10.1: passo 5, immagine 3 di 3
    • Solleva l'aletta di bloccaggio e sfila il cavo a nastro nero dello schermo.
    It's possible to replace only the lcd cable connector? Ist das möglich nur das Flachbandkabel zu tauschen?
    Lima - Replica
  6. Sostituzione batteria Samsung Galaxy Tab A 10.1, Rimuovi la batteria: passo 6, immagine 1 di 2 Sostituzione batteria Samsung Galaxy Tab A 10.1, Rimuovi la batteria: passo 6, immagine 2 di 2
    • Usa un cacciavite a croce Phillips #000 per svitare le dieci viti da 4 mm attorno alla batteria.
    • Infila uno strumento di apertura in plastica sotto il bordo inferiore della batteria vicino allo speaker e sollevala.
    • Il grande rettangolo bianco e nero è l'intera batteria. Stai attento a non forarla.
Conclusione
Per rimontare il dispositivo, segui le istruzioni in ordine inverso.
Altre 46 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
en it
100%
Daniele Carminati ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Isabella Li
Membro da: 10/02/17
2.364 Reputazione
7 Guide realizzate
Cal Poly, Team S15-G6, Livingston Fall 2017 Membro di Cal Poly, Team S15-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G6
4 Membri
26 Guide realizzate
9 Commenti
Used this guide up until the disconnecting of the battery in order to fix the black screen of death. Very very helpful. Thank you.
Steffan Syd Apel - Replica
If you have my kind of bad luck — where the latch for the battery flex cable connector sticks to the tape when you remove the tape, and then it will not snap back into place — don’t worry about it too much, because the connector tension will hold the flex cable in place. Just put the tape back over the top as directed.
Richard Ekblaw - Replica
Why does it say you need a heat gun?
Geert Pante - Replica
To loosen the adhesive. A hair dryer works well too
qaisraja22 -
how to calibrate the new battery?
when device switched off due to 0% of battery - there is impossible to boot it even with charging. there is required to open a tablet and charge the battery from another source.
Алексей Хейдоров - Replica
Used this guide when the device was charging, only showing the charging symbol and it would not turn on. The screen was flickering as well, still wouldn’t turn on. However, this guide helped immensely! Fixed it in a few minutes! Take your time with the clips and make sure that you remove the lever before slowly pulling out the ribbons! Easy Fix!
Jermaine Hall - Replica
Thank you for the guide it worked a treat, no problems what so ever (touch wood).
Derek Anson - Replica
Man beachte, dass um das Glas herum zwei Kunststoff-Lippen laufen. Wenn man das Werkzeug zwischen das Glas und die innere Lippe steckt, würde man nur das Glas abheben. Man muss das Werkzeug zwischen die innere und die äussere Lippe stecken!
Hans Neuendorff - Replica
Many thanks for this guide! Really easy to change the batterie, now it works again.
ElCapi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 19
Ultimi 7 Giorni: 88
Ultimi 30 Giorni: 473
Tutti i Tempi: 63,780
