Introduzione
Use this guide for replacing the motherboard on a Samsung Galaxy Tab 8.9. The guide shows how to disassemble the device to replace the motherboard.
Strumenti
Parti
Nessuna parte specificata.
Insert a plastic opening tool between the back cover and the screen of the Samsung Galaxy Tab 8.9.
Use tweezers to peel up the green tape located on top of the two flexible ribbon cables.
Insert the spudger under the red, black, and white cables.
Pry up and detach the battery from the motherboard.
Use a spudger to lift up and separate the battery from its housing.
Locate the motherboard and 5 connectors on it.
Pry up and detach the connector from the motherboard using the flat edge of the spudger.
Repeat for the 4 remaining connectors.
Altre 3 persone hanno completato questa guida.
