Salta al contenuto principale
Samsung Galaxy Tab 8.9 Battery Replacement
Cosa ti serve
  1. Samsung Galaxy Tab 8.9 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Insert a plastic opening tool between the back cover and the screen of the Samsung Galaxy Tab 8.9.
  2. Samsung Galaxy Tab 8.9 Battery Replacement: passo 2, immagine 1 di 1
    • 6 cm [2 in] away from the first plastic opening tool, insert a second plastic opening tool between the back cover and the screen.
  3. Samsung Galaxy Tab 8.9 Battery Replacement: passo 3, immagine 1 di 1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover from the screen.
  4. Samsung Galaxy Tab 8.9 Battery Replacement: passo 4, immagine 1 di 1
    • Use your hands to open the back cover.
  5. Samsung Galaxy Tab 8.9 Battery Replacement, Remove Green Tape: passo 5, immagine 1 di 3 Samsung Galaxy Tab 8.9 Battery Replacement, Remove Green Tape: passo 5, immagine 2 di 3 Samsung Galaxy Tab 8.9 Battery Replacement, Remove Green Tape: passo 5, immagine 3 di 3
    • Use tweezers to peel up the green tape located on top of the two flexible ribbon cables.
  6. Samsung Galaxy Tab 8.9 Battery Replacement: passo 6, immagine 1 di 2 Samsung Galaxy Tab 8.9 Battery Replacement: passo 6, immagine 2 di 2
    • Insert a spudger under the orange tab.
    • Gently pry up the tab to disconnect the black flexible ribbon cable from the motherboard.
  7. Samsung Galaxy Tab 8.9 Battery Replacement: passo 7, immagine 1 di 3 Samsung Galaxy Tab 8.9 Battery Replacement: passo 7, immagine 2 di 3 Samsung Galaxy Tab 8.9 Battery Replacement: passo 7, immagine 3 di 3
    • Carefully pull out the yellow flexible ribbon cable to disconnect it from the motherboard.
  8. Samsung Galaxy Tab 8.9 Battery Replacement, Disconnect Battery from MotherBoard: passo 8, immagine 1 di 3 Samsung Galaxy Tab 8.9 Battery Replacement, Disconnect Battery from MotherBoard: passo 8, immagine 2 di 3 Samsung Galaxy Tab 8.9 Battery Replacement, Disconnect Battery from MotherBoard: passo 8, immagine 3 di 3
    • Insert the spudger under the red, black, and white cables.
    • Pry up and detach the battery from the motherboard.
  9. Samsung Galaxy Tab 8.9 Battery Replacement: passo 9, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the nine 1 mm screws located around the battery.
  10. Samsung Galaxy Tab 8.9 Battery Replacement, Remove the Battery: passo 10, immagine 1 di 3 Samsung Galaxy Tab 8.9 Battery Replacement, Remove the Battery: passo 10, immagine 2 di 3 Samsung Galaxy Tab 8.9 Battery Replacement, Remove the Battery: passo 10, immagine 3 di 3
    • Use a spudger to lift up and separate the battery from its housing.
Conclusione
Altre 4 persone hanno completato questa guida.
Dan D
Membro da: 09/25/14
160 Reputazione
1 Guida realizzata
USF Tampa, Team 11-4, Blackwell Fall 2014 Membro di USF Tampa, Team 11-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G4
4 Membri
10 Guide realizzate
Un commento
Step 8 Clearer to say:
Insert the spudger under the red, black, and white cables to pry up the battery connector and detach it and the battery from the motherboard.
Paul Jackson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 4,606
