Salta al contenuto principale
Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement
Cosa ti serve
  1. Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Opening the tablet: passo 1, immagine 1 di 3 Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Opening the tablet: passo 1, immagine 2 di 3 Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Opening the tablet: passo 1, immagine 3 di 3
    • Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off.
  2. Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Disconnecting the camera: passo 2, immagine 1 di 1
    • Detach the ribbon cable from the flex cable.
  3. Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Removing the flex cable: passo 3, immagine 1 di 1
    • Detach all ribbon cables from the flex cable, unscrew the flex cable, and remove the flex cable. This needs to be done in order to remove the camera which sits underneath the flex cable.
  4. Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Removing the camera: passo 4, immagine 1 di 1
    • Replace the original camera with the new camera. It should come right out.
Conclusione
USF Tampa, Team 13-2, Staggers Fall 2014 Membro di USF Tampa, Team 13-2, Staggers Fall 2014
USFT-STAGGERS-F14S13G2
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 662
