Introduzione
Use this guide to replace the audio jack when it either ceases to function, or is functioning incorrectly.
Insert the prying tool between the glass screen and the silver binding. Pry around the screen until the screen is separated from the back of the tablet.
  • Insert the prying tool between the glass screen and the silver binding. Pry around the screen until the screen is separated from the back of the tablet.
Aggiungi Commento
Detach the connector that connects the audio jack to the flex cable.
  • Detach the connector that connects the audio jack to the flex cable.
Aggiungi Commento
  • Use the Phillips #00 screwdriver to remove the 2 screws that secure the audio jack in place.
Aggiungi Commento
  • Pick up and remove the defective audio jack.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Stephanie Wong
Membro da: 26/09/2014
919 Reputazione
5 Guide realizzate
USF Tampa, Team 13-2, Staggers Fall 2014 Membro di USF Tampa, Team 13-2, Staggers Fall 2014
USFT-STAGGERS-F14S13G2
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 522
