Salta al contenuto principale
Samsung Galaxy Tab 4 8.0 Verizon Speaker Replacement
Cosa ti serve
  1. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Motherboard: passo 1, immagine 1 di 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Motherboard: passo 1, immagine 2 di 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Motherboard: passo 1, immagine 3 di 3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the metallic rectangular connector from its socket on the mother board.
  2. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: passo 2, immagine 1 di 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: passo 2, immagine 2 di 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: passo 2, immagine 3 di 3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold rectangular connector from its socket on the mother board.
  3. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: passo 3, immagine 1 di 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: passo 3, immagine 2 di 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: passo 3, immagine 3 di 3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold square connector from its socket on the mother board.
  4. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: passo 4, immagine 1 di 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: passo 4, immagine 2 di 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: passo 4, immagine 3 di 3
    • Using the spudger gently wedge the blue wire out of its compartment.
  5. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: passo 5, immagine 1 di 1
    • Remove two 2 mm #000 Phillips screws securing the metallic charger port cover to both the logic board and the front panel.
  6. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: passo 6, immagine 1 di 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: passo 6, immagine 2 di 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: passo 6, immagine 3 di 3
    • Squeeze the metal charger port cover piece with the tweezers to gently lift it from it's place.
  7. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: passo 7, immagine 1 di 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: passo 7, immagine 2 di 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: passo 7, immagine 3 di 3
    • Carefully insert the flat end of the blue plastic opening tool under the black plastic fastener and lift.
    • Rotate your tablet counter clockwise to facilitate the process.
  8. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: passo 8, immagine 1 di 2 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: passo 8, immagine 2 di 2
    • Squeeze the golden cable with the tweezers and gently pull the cable to the left to free the end of the golden cable.
    • The golden cable is delicate so use gentle force.
  9. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: passo 9, immagine 1 di 1
    • Remove three 2 mm #000 Phillips screws securing the mother board to the front panel.
  10. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: passo 10, immagine 1 di 2 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: passo 10, immagine 2 di 2
    • Using your hands, hold the opposite ends of the mother board corners, and lift.
  11. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Speaker: passo 11, immagine 1 di 1
    • Insert the opening tool tip into the crack between the speaker and device.
  12. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: passo 12, immagine 1 di 1
    • Gently pry up on the speaker to disconnect the speaker from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 108
