Salta al contenuto principale
Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement
Cosa ti serve
  1. Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement, Rear Case: passo 1, immagine 1 di 3 Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement, Rear Case: passo 1, immagine 2 di 3 Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement, Rear Case: passo 1, immagine 3 di 3
    • Before disassembling your Samsung Galaxy Tab 4 8.0, be sure it is powered off and you remove the SIM and Micro SD cards.
    • At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
    • Do not use excessive force when prying the clips, fastening the casing together, open because they can easily break.
  2. Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement: passo 2, immagine 1 di 2 Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement: passo 2, immagine 2 di 2
    • Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
    • As right-handers, we found it easiest to move clockwise and use more pressure around the corners to facilitate the process.
    • You might hear several popping noises caused by the plastic clips coming undone.
  3. Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement: passo 3, immagine 1 di 2 Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement: passo 3, immagine 2 di 2
    • To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
    • Firmly grasp the back plastic casing and lift it away from the front assembly panel.
  4. Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement, Rear Facing Camera: passo 4, immagine 1 di 2 Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement, Rear Facing Camera: passo 4, immagine 2 di 2
    • The back camera will be located near the top of the tablet in the center above the battery.
    • Carefully insert the flat end of the blue plastic opening tool under the metal rectangular end of the back camera’s cable connector.
  5. Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement: passo 5, immagine 1 di 1
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the back camera’s metallic rectangular connector from its socket on the logic board.
  6. Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement: passo 6, immagine 1 di 2 Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement: passo 6, immagine 2 di 2
    • Squeeze the metallic rectangular piece with the tweezers to gently lift it from it's pit.
Conclusione
Altre 2 persone hanno completato questa guida.
Yuly Flores
Membro da: 09/14/15
747 Reputazione
1 Guida realizzata
CSU Fullerton, Team 1-3, Bruce Fall 2015 Membro di CSU Fullerton, Team 1-3, Bruce Fall 2015
CSUF-BRUCE-F15S1G3
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 916
