Salta al contenuto principale
Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement
Cosa ti serve
  1. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement, Motherboard: passo 1, immagine 1 di 2 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement, Motherboard: passo 1, immagine 2 di 2
    • Insert the plastic opening tool into the gap between the device frame and the back panel on any side of the device.
    • Slide the opening tool around the edges of the device to disconnect the back panel from the frame.
  2. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 2, immagine 1 di 3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 2, immagine 2 di 3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 2, immagine 3 di 3
    • Carefully remove the back panel from the frame of the device.
  3. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 3, immagine 1 di 3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 3, immagine 2 di 3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 3, immagine 3 di 3
    • Using a Phillips #00 Screwdriver, remove the five 4 mm screws connecting the motherboard to the frame of the device.
  4. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 4, immagine 1 di 3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 4, immagine 2 di 3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 4, immagine 3 di 3
    • Use the plastic opening tool to unlock the battery wire from the motherboard by flipping-up the small retaining flap.
    • Use the tweezers to carefully remove the battery wire from the motherboard by pulling it away from the retainer flap.
  5. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 5, immagine 1 di 3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 5, immagine 2 di 3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 5, immagine 3 di 3
    • Use the plastic opening tool to unlock the wire on the narrow section of the motherboard by flipping-up the retaining flap.
    • Use the tweezers to carefully remove the wire from the motherboard by sliding it away from the retaining flap.
  6. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 6, immagine 1 di 3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 6, immagine 2 di 3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 6, immagine 3 di 3
    • Disconnect the wire near the bottom of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
  7. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 7, immagine 1 di 3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 7, immagine 2 di 3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 7, immagine 3 di 3
    • Disconnect the wire near the top of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
  8. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 8, immagine 1 di 3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 8, immagine 2 di 3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 8, immagine 3 di 3
    • Gently remove the motherboard from the frame of the device by grabbing the top and bottom ends and pulling it toward you.
    • Several plastic tabs keep the motherboard in place, so you will have to apply some force.
  9. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement, Front-Facing Camera: passo 9, immagine 1 di 3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement, Front-Facing Camera: passo 9, immagine 2 di 3 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement, Front-Facing Camera: passo 9, immagine 3 di 3
    • Flip the motherboard over to view the back side.
    • Locate the front-facing camera on the motherboard.
  10. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 10, immagine 1 di 2 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 10, immagine 2 di 2
    • Use a plastic opening tool to unlock the front-facing camera wire from the motherboard by flipping-up the retainer flap.
  11. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 11, immagine 1 di 2 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 11, immagine 2 di 2
    • Use your fingers to grip the camera and carefully pull it out and away from the motherboard.
Conclusione
Cal Poly, Team 18-3, Forte Fall 2016 Membro di Cal Poly, Team 18-3, Forte Fall 2016
CPSU-FORTE-F16S18G3
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 747
