Salta al contenuto principale
Samsung Galaxy Tab 4 7.0 Speaker Replacement
Cosa ti serve
  1. Samsung Galaxy Tab 4 7.0 Speaker Replacement, Back Panel: passo 1, immagine 1 di 2 Samsung Galaxy Tab 4 7.0 Speaker Replacement, Back Panel: passo 1, immagine 2 di 2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Speaker Replacement: passo 2, immagine 1 di 1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Speaker Replacement, Speaker: passo 3, immagine 1 di 2 Samsung Galaxy Tab 4 7.0 Speaker Replacement, Speaker: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • In order the speaker connection, you must first peel back part of the surrounding water gasket.
    • With the tweezers, grab the overhanging corner and peel the gasket back slowly.
    • If you look closely, you will see the two slots indicated. Use the tweezers to lift this portion of the connection away from these slots.
  4. Samsung Galaxy Tab 4 7.0 Speaker Replacement: passo 4, immagine 1 di 2 Samsung Galaxy Tab 4 7.0 Speaker Replacement: passo 4, immagine 2 di 2
    • Now you should be able to lift the speaker out of it's small fitting with the tweezers.
Conclusione
Altre 2 persone hanno completato questa guida.
Aubrey Goodwin
Membro da: 08/31/15
2.700 Reputazione
3 Guide realizzate
USF Tampa, Team 1-3, Remmell Fall 2015 Membro di USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
4 Membri
12 Guide realizzate
2 Commenti
Where can I order the new speaker?
Dorrie Stotko - Replica
This would be better if it were a YouTube video so we could actually see it being done.
robinmyrobin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 3,952
