Salta al contenuto principale
Introduzione
The front and rear facing cameras are both right next to each other and require the same tools and process for removal.
  1. Starting from any corner of the tablet, carefully insert the plastic pry tool into the gap between the chrome frame and black back panel. Slide the pry tool around the  tablet to release the plastic locking clips. Pry the back plastic case down and slightly away from the device while the screen is facing up. Slide the pry tool around the  tablet to release the plastic locking clips. Pry the back plastic case down and slightly away from the device while the screen is facing up.
    • Starting from any corner of the tablet, carefully insert the plastic pry tool into the gap between the chrome frame and black back panel.
    • Slide the pry tool around the tablet to release the plastic locking clips. Pry the back plastic case down and slightly away from the device while the screen is facing up.
  2. Carefully separate the rear case from the front panel assembly .
    • Carefully separate the rear case from the front panel assembly .
    • At this point, you will be able to complete any component replacements necessary.
  3. To begin the replacement of the motherboard, identify the wire strip connections that must be removed.
    • To begin the replacement of the motherboard, identify the wire strip connections that must be removed.
    • These connections can be removed using tweezers.
    • These chip connections can be released using the plastic opening tool.
  4. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  5. Do not bend the wire strips at the tips as they may become permanently deformed. Using the bent tweezers, carefully grasp wire strips and pull away from the connectors.
    • Do not bend the wire strips at the tips as they may become permanently deformed.
    • Using the bent tweezers, carefully grasp wire strips and pull away from the connectors.
  6. For the chip connections, simply use the plastic opening tool to gently pry and separate the connection. For the chip connections, simply use the plastic opening tool to gently pry and separate the connection.
    • For the chip connections, simply use the plastic opening tool to gently pry and separate the connection.
  7. Now you will need your phillips head screwdriver to remove the remaining 5 x 1.2 mm PH000 screws. And don't forget "righty tighty, lefty loosey" And don't forget "righty tighty, lefty loosey"
    • Now you will need your phillips head screwdriver to remove the remaining 5 x 1.2 mm PH000 screws.
    • And don't forget "righty tighty, lefty loosey"
  8. The final step of removing the motherboard should be done with extreme care as to not damage the board itself. Gently grab both ends of the motherboard and rotate it towards you. It should release easily from the case.
    • The final step of removing the motherboard should be done with extreme care as to not damage the board itself.
    • Gently grab both ends of the motherboard and rotate it towards you. It should release easily from the case.
    • Now you've successfully removed the motherboard!
  9. With the tweezers grab the base of the wire harness and slide it outward in the direction shown. This can be done for either camera on the tablet. This can be done for either camera on the tablet.
    • With the tweezers grab the base of the wire harness and slide it outward in the direction shown.
    • This can be done for either camera on the tablet.
Conclusione
Altre 6 persone hanno completato questa guida.
Aubrey Goodwin
Membro da: 31/08/2015
2.302 Reputazione
3 Guide realizzate
USF Tampa, Team 1-3, Remmell Fall 2015 Membro di USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
4 Membri
12 Guide realizzate
My camera on the Tab 4 is fine, but the len on the back is scratched. Can I get a replacement for the lens? If so where can I purchase this and is it comparable with other Tabs or Cells lens. I am not looking for a camera, Im look for the glass that protects the said camera.
Amanda Ellenberger - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 25
Tutti i Tempi: 3,399
