Salta al contenuto principale
Samsung Galaxy Tab 4 7.0 Battery Replacement
Cosa ti serve
Panoramica Video
  1. Samsung Galaxy Tab 4 7.0 Battery Replacement, Back Panel: passo 1, immagine 1 di 2 Samsung Galaxy Tab 4 7.0 Battery Replacement, Back Panel: passo 1, immagine 2 di 2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Battery Replacement: passo 2, immagine 1 di 1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Battery Replacement, Battery: passo 3, immagine 1 di 3 Samsung Galaxy Tab 4 7.0 Battery Replacement, Battery: passo 3, immagine 2 di 3 Samsung Galaxy Tab 4 7.0 Battery Replacement, Battery: passo 3, immagine 3 di 3
    • You do not need to remove the motherboard in order to remove the battery as the photos may indicate.
    • Work the spudger underneath the battery as shown and pry the battery away from the phone case.
    • The battery is attached to the case with adhesive, so a bit of force is required during removal.
Conclusione
Altre 28 persone hanno completato questa guida.
USF Tampa, Team 1-3, Remmell Fall 2015 Membro di USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
4 Membri
12 Guide realizzate
3 Commenti
This is for a cell phone, not a tablet. Why?
ckmjunk - Replica
it is the tablet
sourcandysaiyan -
OH! its so easy!! woohoo, ordering battery now!
sourcandysaiyan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 49
Tutti i Tempi: 26,713
