Introduzione
This replacement guide will walk you through how to replace the motherboard on your Samsung Galaxy Tab 3 Lite. Before doing this, you will need to remove the back case of your tablet first. The guide for how to do that is also included here.
Cosa ti serve
Using a plastic opening tool, wedge in the seam between the screen and the case.
Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
This is a long process, so don't try and rush it. Also, be careful about applying pressure.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Use a plastic opening tool to lift up the zero insertion force (ZIF) connector holding down the ribbon cable.
Use the precision tweezers to gently pull the ribbon cable out of the ZIF connector.
Altre 21 persone hanno completato questa guida.
3 Commenti
Thank you friend!
Nice guide, Done very well.
Ótimo guia. Esses tutoriais facilitam demais nossa vida. Sou fã! Parabéns
