Salta al contenuto principale
Samsung Galaxy Tab 3 Lite Battery Replacement
Cosa ti serve
  1. Samsung Galaxy Tab 3 Lite Battery Replacement, Rear Case: passo 1, immagine 1 di 3 Samsung Galaxy Tab 3 Lite Battery Replacement, Rear Case: passo 1, immagine 2 di 3 Samsung Galaxy Tab 3 Lite Battery Replacement, Rear Case: passo 1, immagine 3 di 3
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
    • This is a long process, so don't try and rush it. Also, be careful about applying pressure.
  2. Samsung Galaxy Tab 3 Lite Battery Replacement: passo 2, immagine 1 di 3 Samsung Galaxy Tab 3 Lite Battery Replacement: passo 2, immagine 2 di 3 Samsung Galaxy Tab 3 Lite Battery Replacement: passo 2, immagine 3 di 3
    • After separating the tape holding the screen and case together, slowly start taking the screen off the case from the opposite side of the side with the buttons
  3. Samsung Galaxy Tab 3 Lite Battery Replacement, Battery: passo 3, immagine 1 di 3 Samsung Galaxy Tab 3 Lite Battery Replacement, Battery: passo 3, immagine 2 di 3 Samsung Galaxy Tab 3 Lite Battery Replacement, Battery: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Locate the ZIF ( zero insertion force) connector highlighted by the red circle, as shown in the provided picture.
    • Use the plastic opening tool to gently lift the black ZIF connector shown within the red circle. It should just pop out with relative ease.
    • Use the precision tweezers and gently pull out the black cable out of its slot.
  4. Samsung Galaxy Tab 3 Lite Battery Replacement: passo 4, immagine 1 di 2 Samsung Galaxy Tab 3 Lite Battery Replacement: passo 4, immagine 2 di 2
    • Use the plastic opening tool to gently lift black flap shown within the red circle. It should just pop out with relative ease.
    • Now gently pull out the yellowish orange ribbon cable, similar to how you did in Step 1.
  5. Samsung Galaxy Tab 3 Lite Battery Replacement: passo 5, immagine 1 di 3 Samsung Galaxy Tab 3 Lite Battery Replacement: passo 5, immagine 2 di 3 Samsung Galaxy Tab 3 Lite Battery Replacement: passo 5, immagine 3 di 3
    • Use the plastic opening tool and gently pry out the battery from the left-hand side.
    • Grab the battery and lift it up.
    • It should come off with no extra effort, since both the black and yellowish orange cables have been pulled out.
Conclusione
Altre 15 persone hanno completato questa guida.
Kevin Hicks
Membro da: 02/09/16
1.575 Reputazione
2 Guide realizzate
USF Tampa, Team 11-1, Cheng Spring 2016 Membro di USF Tampa, Team 11-1, Cheng Spring 2016
USFT-CHENG-S16S11G1
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 64
Tutti i Tempi: 13,733
