Cosa ti serve
Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
After the battery is disconnected, use the pulling tab to safely remove the battery.
With a plastic remover tool, gently unseat the connection of the proximity sensor to the motherboard.
Gently wedge the plastic remover tool and pry antenna loose, and lift it from the proximity sensor. The Sensor can then simply lifted from the device.
