Salta al contenuto principale
Samsung Galaxy Tab 3 8.0 Front Camera Replacement
Cosa ti serve
  1. Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Battery - Open up the tablet: passo 1, immagine 1 di 2 Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Battery - Open up the tablet: passo 1, immagine 2 di 2
    • Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
    • Be careful when removing the screen as negligence can cause damage.
  2. Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Remove Back Cover: passo 2, immagine 1 di 2 Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Remove Back Cover: passo 2, immagine 2 di 2
    • Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
  3. Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Disconnect Battery: passo 3, immagine 1 di 2 Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Disconnect Battery: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
    • Note: the connection lifts up to remove.
  4. Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Remove Battery: passo 4, immagine 1 di 1
    • After the battery is disconnected, use the pulling tab to safely remove the battery.
  5. Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Remove the Front Camera: passo 5, immagine 1 di 3 Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Remove the Front Camera: passo 5, immagine 2 di 3 Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Remove the Front Camera: passo 5, immagine 3 di 3
    • Take the plastic remover tool and gently lift the component free from the motherboard.
Conclusione
USF Tampa, Team 4-2, Brown Fall 2014 Membro di USF Tampa, Team 4-2, Brown Fall 2014
USFT-BROWN-F14S4G2
3 Membri
26 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 701
