Salta al contenuto principale
Samsung Galaxy Tab 3 7.0 Battery Replacement
Cosa ti serve
Panoramica Video
  1. Samsung Galaxy Tab 3 7.0 Battery Replacement, Battery: passo 1, immagine 1 di 2 Samsung Galaxy Tab 3 7.0 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • With a plastic opening tool, gently insert the prying end in between the glass digitizer and the silver frame from the front of the device.
    I tried this with my Galaxy Tab A. I only wanted to remove the front and rear cameras.
    wmcarroll13 - Replica
    How hard do i need to push the plastic part? i tried it but i wont pop off.
    Emil Klock - Replica
  2. Samsung Galaxy Tab 3 7.0 Battery Replacement: passo 2, immagine 1 di 3 Samsung Galaxy Tab 3 7.0 Battery Replacement: passo 2, immagine 2 di 3 Samsung Galaxy Tab 3 7.0 Battery Replacement: passo 2, immagine 3 di 3
    • Working slowly and carefully, move around the entirety of the face of the device. Small plastic clips should release, if not, apply gentle outwards pressure until you hear the clips popping off.
    I used a dull knife blade and just slide it along the grove. You may have to slide the knife back and forth a couple of times but, the cover will unsnap.
  3. Samsung Galaxy Tab 3 7.0 Battery Replacement: passo 3, immagine 1 di 3 Samsung Galaxy Tab 3 7.0 Battery Replacement: passo 3, immagine 2 di 3 Samsung Galaxy Tab 3 7.0 Battery Replacement: passo 3, immagine 3 di 3
    • To begin actual removal of the battery itself, remove the four designated screws with your screwdriver.
    • Once the screws are removed, use either the tip of your screwdriver or a pair of tweezers to pull up the battery connector. Pull directly up and the connector should pop out.
    • Once the battery is removed, it should look as it does in the third picture.
    Gently lift the battery from the inside edge using the battery connector. The battery is hinged on the outside edge by two plastic protrusions which fit into the plastic frame where the battery is located.
    markiratcliffe1 - Replica
    Because I was only removing the cameras, I did not have to touch the battery. However on the motherboard; there are 4 screws up top you have to remove. Where your headphones plug in; gently pull up the connector away from the board. Tilt the motherboard up at a 45-60 degree angle. With a pair of tweezers, pull both cameras up (one at a time) while pulling side to side. The connectors will slide out. Then make sure the bottom of motherboard is slipped under small tabs then replace screws up top. Snap connector for earphones back into place.
  4. Samsung Galaxy Tab 3 7.0 Battery Replacement: passo 4, immagine 1 di 1
    • To finish battery replacement, place your new battery where the old battery was in your device, as shown in the picture.
    Don't forget to insert the battery on the outside edge first, locating the plastic protrusions into the frame around the battery. Use the tip of your screwdriver to push down on the protrusions to locate them in the frame. Once the battery is located correctly, it should sit flush with the frame that surrounds it.
    No explanation of how to separate the glass from the body in order to access the battery.
    randyshelly - Replica
    Its the 1st step, pry tool down between glass and edge, all the way round. It has pressure clips
    robert.stevens89 - Replica
Conclusione
Altre 57 persone hanno completato questa guida.
Ian Leonard
Membro da: 04/22/14
469 Reputazione
1 Guida realizzata
Cal Poly, Team 7-20, Regan Spring 2014 Membro di Cal Poly, Team 7-20, Regan Spring 2014
CPSU-REGAN-S14S7G20
4 Membri
10 Guide realizzate
6 Commenti
Don't forget to reset the time and date when your done.
Some of the apps will not work and the operating system will not tell you that this is the problem.
cpessaro - Replica
good job for making this as least complicated as possible i completed the guide
Alburt Einstine - Replica
Great guide..... If you don't have the plastic tool, my thumb nail worked just fine
Bruce Wiggins - Replica
Thanks for this great guide.
When attaching the new battery it helped me to actually attach the wiring connector before final placement of the battery. Also, I found it easier to put the single screw in first before pushing the battery all the way down and starting the three on the other side. The cscrew holes in the replacement battery have to be PERFECT and if they’re just slightly off you can’t get the one lonely screw started if you put the other three in first.
Tkappock - Replica
I enjoied the guide it was realy easy the video was varry helpfull. I do have a question is there any way to test the batery to make sure that is realy the problem, before i go replaycing it?
John Tahos - Replica
That’s a confusing first picture, implying the seam is below /behind instead of above/in front of the card slots. Was it chosen to suggest a clearance issue requiring removal of the SD and SIM cards before the back and sides come off?
duncan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 80
Tutti i Tempi: 165,394
