Introduzione
This guide will show you how to replace and repair both Front and Rear cameras on the device.
To begin working on your repair, turn your device over and open the micro SD slot, as shown in the first picture.
  • To begin working on your repair, turn your device over and open the micro SD slot, as shown in the first picture.
  • Using the flat part of the spudger, begin pushing it between the white backing and the SD slot. Continue to pry off the white backing until you hear several clicks and see the white backing lift up, as shown in the second picture.
  • Continue to pry off the white backing around the device, as shown in the third picture.
Aggiungi Commento
Once the backing has been pried off all around the device, remove the white backing.
  • Once the backing has been pried off all around the device, remove the white backing.
Aggiungi Commento
  • To remove the silver siding, begin by pushing the spudger between the frame and the screen, as shown in the first picture.
  • Do this until you see the silver siding begin to lift up. Continue doing this around the edges of the device, as shown in the second picture.
  • Once you silver siding is loose all around the device, remove it carefully with your hand as shown in the third picture.
Aggiungi Commento
  • Begin by removing the four designated 1.33x2.00 mm Phillips screws with the screwdriver, as shown in the first picture.
  • Once the screws are removed, use a pair of tweezers or the spudger to remove the battery connector.
  • Pull the battery connector up as shown in the second picture.
  • Once the battery connector is removed, you can remove the battery using the spudger as shown in the third picture.
I found it easier to start with the USB. And like others, there was no need to remove the siding. The battery was held in with double-backed tape. Thanks
John Keenliside - Replica
  • To begin replacing mother board, remove the six flat-topped connectors shown in the first picture.
  • Remove the connections by pulling them up carefully using a spudger or tweezers, as shown in the second picture.
Aggiungi Commento
  • First, Remove eight 1.33x2.00mm Phillip screws.
  • Once all the screws are removed, remove the motherboard using the tweezers.
  • Once the motherboard is removed, your device should look like the device in the third picture.
Aggiungi Commento
  • Using tweezers or the spudger, remove the flat-topped connector that is shown in the first picture.
  • Once the connector is detached, remove the rear camera using tweezers, as shown in the second and third pictures.
Aggiungi Commento
  • Begin removing the front camera by popping off the plastic stopper shown in the first picture.
  • Remove the plastic stopper with tweezers as shown in the second picture
Aggiungi Commento
  • Once the plastic stopper is removed, use tweezers to remove the flat-topped connector for the front camera.
  • Be careful and gentle when removing the connection for the front camera. You may want to use a heat source, such as a heat gun or a blow dryer, to dissipate the glue.
  • Once the connection is unconnected, remove both the connector and the camera.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Andrea Flores
Membro da: 09/10/2014
1.426 Reputazione
6 Guide realizzate
Cal Poly, Team 14-30, Maness Fall 2014 Membro di Cal Poly, Team 14-30, Maness Fall 2014
CPSU-MANESS-F14S14G30
4 Membri
18 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 506
