Salta al contenuto principale
Ricambi
Nessuna parte specificata.
  1. Insert an opening pick between the rear case and the plastic rim. You may need to add multiple picks to detach the clips.
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Lift the case up to remove it. Lift the case up to remove it.
    • Lift the case up to remove it.
Conclusione
Altre 2 persone hanno completato questa guida.
Corey Brown
Membro da: 24/06/2016
7.451 Reputazione
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,603
