Salta al contenuto principale
Samsung Galaxy Tab 3 10.1 LED Light Replacement
Cosa ti serve
  1. Samsung Galaxy Tab 3 10.1 LED Light Replacement, Rear Case: passo 1, immagine 1 di 2 Samsung Galaxy Tab 3 10.1 LED Light Replacement, Rear Case: passo 1, immagine 2 di 2
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 LED Light Replacement: passo 2, immagine 1 di 2 Samsung Galaxy Tab 3 10.1 LED Light Replacement: passo 2, immagine 2 di 2
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 LED Light Replacement, LED Light: passo 3, immagine 1 di 2 Samsung Galaxy Tab 3 10.1 LED Light Replacement, LED Light: passo 3, immagine 2 di 2
    • Insert an opening pick between the plastic frame and the screen.
    • Slide the opening pick around the perimeter of the screen.
    • You will hear clicking noises as each plastic clip is released from the display chassis.
  4. Samsung Galaxy Tab 3 10.1 LED Light Replacement: passo 4, immagine 1 di 1
    • Lift the plastic frame to remove.
    • Avoid the three delicate ribbon cables.
  5. Samsung Galaxy Tab 3 10.1 LED Light Replacement: passo 5, immagine 1 di 3 Samsung Galaxy Tab 3 10.1 LED Light Replacement: passo 5, immagine 2 di 3 Samsung Galaxy Tab 3 10.1 LED Light Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use the flat end of the spudger to flip up the press-fit connector attaching the LED to the motherboard.
    • Remove the LED indicator light by gently pulling upward with nylon-tipped tweezers.
Conclusione
Altre 5 persone hanno completato questa guida.
Corey Brown
Membro da: 06/24/16
8.826 Reputazione
11 Guide realizzate
Un commento
Above article is useful for removing LED Light.
Which LED are we removing - Camera Flash or screen display LED?
How to fit new LED Light?
Please reply. I am facing issues with screen display and flash for camera is also not working
Ashwini Dughad - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 24
Tutti i Tempi: 4,248
