Salta al contenuto principale
Samsung Galaxy Tab 2 7.0 Speaker Replacement
Cosa ti serve
  1. Samsung Galaxy Tab 2 7.0 Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Using a nylon spudger or flat plastic opening tool, pry open the back of the device.
    • It is easy to begin this process by starting at the micro SD card insert, as shown in the pictures.
  2. Samsung Galaxy Tab 2 7.0 Speaker Replacement: passo 2, immagine 1 di 2 Samsung Galaxy Tab 2 7.0 Speaker Replacement: passo 2, immagine 2 di 2
    • Using a phillips head screwdriver, remove the two 4mm screws holding down each speaker.
  3. Samsung Galaxy Tab 2 7.0 Speaker Replacement: passo 3, immagine 1 di 3 Samsung Galaxy Tab 2 7.0 Speaker Replacement: passo 3, immagine 2 di 3 Samsung Galaxy Tab 2 7.0 Speaker Replacement: passo 3, immagine 3 di 3
    • Locate the flex cable attaching each speaker to the motherboard.
    • Carefully use a nylon spudger to lift the cable and detach it from the motherboard.
    • Lift the speaker out of the device.
    • If the speaker does not come out easily, use a flat tool under the flex cable to slightly lift the speaker out of place before removing it with your hands.
    • Be careful when working with flex cables. Excessive force and sharp tools have the potential to damage these components.
Conclusione
IUPUI, Team S3-G1, Harley Spring 2017 Membro di IUPUI, Team S3-G1, Harley Spring 2017
IUPUI-HARLEY-S17S3G1
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 13
Tutti i Tempi: 739
