Cosa ti serve
Power the device down completely
Remove the SD card from the SD card slot.
Using the Phillips #00 precisions screwdriver, remove the 12 4mm screws holding in the motherboard.
Release all flex cables on the upper portion of the motherboard.
Using the plastic pry tool release the sensor flex cable from its socket.
With the same tool release the camera flex cable from its socket.
Release the front camera flex cable from its socket.
Release the side button's flex cable from its socket.
Press gently from the back of the device to loosen the LCD screen until it separates.
Altre 2 persone hanno completato questa guida.
