Cosa ti serve
00 Phillips Driver Bit
Plastic and Metal Prying Tools
Plastic Spudger
Get a pry tool and go along the edge of the cover
Twist the pry tool to un-clip the clips
Get a plastic spudger and push upwards on the underside of the connector
Then unscrew the battery from the body.
Then you can remove the battery by simply lifting it out of the case.
Un-screw the two screws on each of the speakers.
Use the plastic spudger to un-clip the connectors. These work like Lego bricks.
You can then remove the speakers.
Un-clip all of the ribbon connectors from the board.
Un-screw all of the screws from the board.
You can then remove the metal shield from the board.
After, you can remove the motherboard by pulling up from the top and slide it out of the power connector port.
You can then remove the components such as the cameras and the mic.
To remove the headphone jack you un-screw the metal bracket.
Altre 11 persone hanno completato questa guida.
