Salta al contenuto principale
Samsung Galaxy Tab 2 7.0 Camera Replacement
Cosa ti serve
  1. Samsung Galaxy Tab 2 7.0 Camera Replacement, Camera: passo 1, immagine 1 di 1
    • Using a nylon spudger or a flat plastic opening tool, pry open the back of the device.
    • It is easiest to begin this process by starting at the micro SD card insert, as shown in the pictures.
  2. Samsung Galaxy Tab 2 7.0 Camera Replacement: passo 2, immagine 1 di 1
    • Using a phillips head screwdriver, remove the 6 4mm screws holding the battery on the device.
    • Remove the battery, and set it aside.
  3. Samsung Galaxy Tab 2 7.0 Camera Replacement: passo 3, immagine 1 di 1
    • Using a phillips head screwdriver, remove the 6 4mm screws holding the motherboard in the device.
  4. Samsung Galaxy Tab 2 7.0 Camera Replacement: passo 4, immagine 1 di 3 Samsung Galaxy Tab 2 7.0 Camera Replacement: passo 4, immagine 2 di 3 Samsung Galaxy Tab 2 7.0 Camera Replacement: passo 4, immagine 3 di 3
    • Locate the 8 flex cables attached to the motherboard.
    • Using a nylon spudger, gently detach each flex cable from the motherboard.
    • Be careful when detaching flex cables. Excessive force and sharp objects have the potential to damage these components.
    • Lift the motherboard from the device and set it aside.
  5. Samsung Galaxy Tab 2 7.0 Camera Replacement: passo 5, immagine 1 di 1
    • Locate the camera towards the top of the device.
    • Use a nylon spudger to gently lift the camera and remove it from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
IUPUI, Team S3-G1, Harley Spring 2017 Membro di IUPUI, Team S3-G1, Harley Spring 2017
IUPUI-HARLEY-S17S3G1
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 649
