Salta al contenuto principale
Introduzione
If your Samsung Galaxy Tab 2 10.1 tablet does not turn on (even after being charged) or the battery does not last as long as it used to, the battery may need to be replaced.
This guide demonstrates how to replace the battery in your tablet.
Caution: Some images display the steps using a metal spudger. Use the heavy-duty spudger instead to avoid damaging your circuits.
For more information on connectors, visit this page.
  1. Samsung Galaxy Tab 2 10.1 Battery Replacement, Back Cover: passo 1, immagine 1 di 2 Samsung Galaxy Tab 2 10.1 Battery Replacement, Back Cover: passo 1, immagine 2 di 2
    • The plastic opening tool may break during this step. You may need to use the heavy duty spudger instead.
    • Insert the plastic opening tool between the glass screen and the back cover so the curved end of the plastic opening tool is under the glass. Gently pry the back cover away from the glass screen.
    • Be sure to lift the entire display from the body and that you are not are lifting the glass from the display. You will need to reach down a little further for the correct removal.
    • Continue inserting the plastic opening tool around the whole device screen to completely separate the back cover from the glass screen.
    Note that the headphone port protrudes into the back cover framing. Hence the rest of the back needs to be unclipped and taken off first.
    Levi Howard - Replica
    I had problems getting it to separate at first. Pushing down with my thumb on the very edge of the case from the front while pushing up with my fingers from the back flexed it enough to get a very small jeweler’s screwdriver in the gap. From there I worked it until I could get the little bread wrapper plastics clips in the space. When it needed something stronger a 1 or 2 inch plastic putty knife from Walmart did the trick.
    William H Bowers - Replica
    I replaced the battery and nothing no screen nothing. the batt was 3.7 V though.
    The old one had 0V. I might have messed up the ribbon cables?
    I put back the cover on it.
    Held on the power button for 10 seconds, nothing. Held the power button and the volume up button for 10 seconds… also nothing..
    I am leaving it charge for a while now. Even though if your battery is like full (3.7V measured) it should come on… but nothing..
    Lets wait and see. Or this will be garbage…
    xbox40489 - Replica
  2. Samsung Galaxy Tab 2 10.1 Battery Replacement: passo 2, immagine 1 di 2 Samsung Galaxy Tab 2 10.1 Battery Replacement: passo 2, immagine 2 di 2
    • Gently lift the screen up with your finger.
    • If the screen will not separate from the back cover, try repeating step 1.
  3. Samsung Galaxy Tab 2 10.1 Battery Replacement, Battery Disconnect: passo 3, immagine 1 di 1
    • Using your fingers, remove the green tape covering the battery connector.
  4. Samsung Galaxy Tab 2 10.1 Battery Replacement: passo 4, immagine 1 di 3 Samsung Galaxy Tab 2 10.1 Battery Replacement: passo 4, immagine 2 di 3 Samsung Galaxy Tab 2 10.1 Battery Replacement: passo 4, immagine 3 di 3
    • Insert the flat end of the heavy-duty spudger between the wires and underneath the battery connector. Carefully lift the black battery connector up to disconnect it from the motherboard.
    • The metal spudger shown in the photo is not recommended due to the possibility of an electrical short. Use an ESD-safe tool, such as a heavy-duty (nylon) spudger.
  5. Samsung Galaxy Tab 2 10.1 Battery Replacement, Battery: passo 5, immagine 1 di 3 Samsung Galaxy Tab 2 10.1 Battery Replacement, Battery: passo 5, immagine 2 di 3 Samsung Galaxy Tab 2 10.1 Battery Replacement, Battery: passo 5, immagine 3 di 3
    • Using your fingers, remove the green tape holding the three ribbon cables down.
    • Using the flat end of the heavy-duty spudger, carefully lift the black tab that holds the leftmost, black ribbon cable in place. Repeat this step for the gold ribbon cable and the black ribbon cable.
    • Using your fingers, gently slide each of the three cables straight out of the connectors.
  6. Samsung Galaxy Tab 2 10.1 Battery Replacement: passo 6, immagine 1 di 1
    • Using a Phillips #000 screwdriver, remove the ten 3mm screws that hold the battery down.
  7. Samsung Galaxy Tab 2 10.1 Battery Replacement: passo 7, immagine 1 di 2 Samsung Galaxy Tab 2 10.1 Battery Replacement: passo 7, immagine 2 di 2
    • Lift the battery with your hands and remove it from the device.
    It would be helpful to advise that the headphone port protrudes and hence the back needs to be taken off with that in mind (ie, the rest of the back first)
    trés bonnes explications…. Changement de batterie réussi MAIS impossible de remettre les nappes en place…Craignant ce problème je n’avais pas débranché celle du milieu; la batterie glisse dessous….J’aurais du le faire pour les autres! La tablette va à la déchetterie!
    5puy32@orange.fr - Replica
    xbox40489 - Replica
    I'm in the same situation, coming from a fully depleted/broken battery.
    Were you able to start the tablet?
    Thanks!
    Carlos Iván Conde Martín -
Conclusione
Altre 53 persone hanno completato questa guida.
Daniel Rostom
Membro da: 02/02/2015
795 Reputazione
2 Guide realizzate
9 Commenti
I changed my battery and also the charging port/ribbon cable..... Could someone help me figure out why it still won't show anything on screen or turn on ? It's never been dropped, started having a problem with charging issues so decided it must be battery, port, or charger. So I bought all three and still no change ? help!!
K W - Replica
Sorry I don't have any help for you, but it sounds like I am having the same issue as you. Please let me know if you solve your problem.
mooseintheuk -
Does this really work?
Cristopher Arias - Replica
How to check charging voltage o battery terminal .
naveedstc - Replica
Hello KW
Please go through in service manaula available on net and follow step by step like as
1- if have battery voltage more than 3.7 it meas your battery is OK and then go next step
2- check conenctor FPCB(SLC500) is fixed properly.
3- check voltage on ZD500 volagte when you press the on -off swicth ZD500 Voltage
have to same V_BATT voltage if no then replace power swicth .
4- Please Check U700(PMIC) and Power
on voltage(C760≥1.0V, C758≥
1.1V, C757≥1.0V, C755≥1.0V,
C754≥1.2V, C753≥1.35V,
C752≥2.0V) if volagte is not OK then replace U 7000.
good luck
naveedstc - Replica
I have that tablet for 5 yrs now and it started to give me problems 3 yrs ago and at obe point it went dead… then it cameback but is really slow and it freezes… do battery replacement works??? Tks. Liette
lsaintamand42 - Replica
Do replacement battery work if tablet is 5-6 yrs old???
I had a problem with my Tab “ 10.1
I was silly enough to let the battery drain completely.
The result was that when i tried to charge it, I got the charging logo, followed by the battery symbol, but instead of filling the symbol with gold bars, only one gold bar was displayed for about second, before the tablet shut down.
The tab would repeat this cycle over and over again, regardless of how long I had it plugged in to the charger (over 24hrs)
I followed the above instructions, left the battery in place, but disconnected it from the motherboard for minute or so.
Once reassembled and plugged back in to the charger, the tab started charging as normal right away
Many thanks to the author for a fantastic 15 minute fix
ATB
Russ
Russell Greenacre - Replica
xbox40489 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 96
Ultimi 30 Giorni: 468
Tutti i Tempi: 80,610
