Salta al contenuto principale
Introduzione
This guide will teach you how to remove the back cover from your tablet, a prerequisite step to the other guides.
Parti
Nessuna parte specificata.
  1. The plastic opening tool may break during this step. You may need to use the heavy duty spudger instead. Insert the plastic opening tool between the glass screen and the back cover so the curved end of the plastic opening tool is under the glass. Gently pry the back cover away from the glass screen.
    • The plastic opening tool may break during this step. You may need to use the heavy duty spudger instead.
    • Insert the plastic opening tool between the glass screen and the back cover so the curved end of the plastic opening tool is under the glass. Gently pry the back cover away from the glass screen.
    • Be sure to lift the entire display from the body and that you are not are lifting the glass from the display. You will need to reach down a little further for the correct removal.
    • Continue inserting the plastic opening tool around the whole device screen to completely separate the back cover from the glass screen.
  2. Gently lift the screen up with your finger. If the screen will not separate from the back cover, try repeating step 1.
    • Gently lift the screen up with your finger.
    • If the screen will not separate from the back cover, try repeating step 1.
Conclusione
Gabriel Rodarte
Membro da: 08/02/2015
423 Reputazione
2 Guide realizzate
Cal Poly, Team 6-26, Amido Winter 2015 Membro di Cal Poly, Team 6-26, Amido Winter 2015
CPSU-AMIDO-W15S6G26
5 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 198
