Salta al contenuto principale
Samsung Galaxy Tab 10.1 Rear Panel Replacement
Cosa ti serve
  1. Samsung Galaxy Tab 10.1 Rear Panel Replacement, Rear Panel: passo 1, immagine 1 di 2 Samsung Galaxy Tab 10.1 Rear Panel Replacement, Rear Panel: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Place the bottom of the tablet towards you.
    • Remove the 4.1mm screws near the charge port with a Tri-Wing screwdriver.
    • If there are plastic tabs covering these screws, use pointed tweezers to pry the tabs out.
    • On model GT-P7500, this step is omitted, as that model doesn't have these 2 screws.
  2. Samsung Galaxy Tab 10.1 Rear Panel Replacement: passo 2, immagine 1 di 3 Samsung Galaxy Tab 10.1 Rear Panel Replacement: passo 2, immagine 2 di 3 Samsung Galaxy Tab 10.1 Rear Panel Replacement: passo 2, immagine 3 di 3
    • Start in the middle of the left side and insert a plastic opening tool between the rear panel and the front panel assembly.
    • Carefully run the plastic opening tool along the left and top edge to pry the rear panel away from the rest of the device.
    • Place opening picks along the side you have already pried open to keep the back panel detached from the rest of the device.
    • Be sure to work carefully, as prying too firmly can crack the screen.
  3. Samsung Galaxy Tab 10.1 Rear Panel Replacement: passo 3, immagine 1 di 3 Samsung Galaxy Tab 10.1 Rear Panel Replacement: passo 3, immagine 2 di 3 Samsung Galaxy Tab 10.1 Rear Panel Replacement: passo 3, immagine 3 di 3
    • Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel.
Conclusione
Altre 13 persone hanno completato questa guida.
Davie Sy
Membro da: 09/30/13
1.430 Reputazione
4 Guide realizzate
Cal Poly, Team 13-5, Forte Fall 2013 Membro di Cal Poly, Team 13-5, Forte Fall 2013
CPSU-FORTE-F13S13G5
5 Membri
17 Guide realizzate
4 Commenti
Very interesting, but my note 10.1 does not have these two screws adjacent to the charge point as you describe. So mine is a bit different. There are no screws anywhere on the tablet. So how do I take the back off mine ??
James Tobin - Replica
It currently won’t start and I have read about a fix that requires the back to be removed.
What - How - Ware ? Yes I looked online for the parts, no I was not successful in finding the parts online. Can you tell me ware you found the parts for this project?
Brian Elling - Replica
i need the panel
Ay Bami - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 24
Tutti i Tempi: 39,516
