Salta al contenuto principale
Samsung Galaxy Tab 10.1 Motherboard Replacement
Cosa ti serve
  1. Samsung Galaxy Tab 10.1 Motherboard Replacement, Rear Panel: passo 1, immagine 1 di 2 Samsung Galaxy Tab 10.1 Motherboard Replacement, Rear Panel: passo 1, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • Place the bottom of the tablet towards you.
    • Remove the 4.1mm screws near the charge port with a Tri-Wing screwdriver.
    • If there are plastic tabs covering these screws, use pointed tweezers to pry the tabs out.
    • On model GT-P7500, this step is omitted, as that model doesn't have these 2 screws.
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung Galaxy Tab 10.1 Motherboard Replacement: passo 2, immagine 1 di 3 Samsung Galaxy Tab 10.1 Motherboard Replacement: passo 2, immagine 2 di 3 Samsung Galaxy Tab 10.1 Motherboard Replacement: passo 2, immagine 3 di 3
    • Start in the middle of the left side and insert a plastic opening tool between the rear panel and the front panel assembly.
    • Carefully run the plastic opening tool along the left and top edge to pry the rear panel away from the rest of the device.
    • Place opening picks along the side you have already pried open to keep the back panel detached from the rest of the device.
    • Be sure to work carefully, as prying too firmly can crack the screen.
    Chiedi a FixBot
    Aggiungi Commento
  3. Samsung Galaxy Tab 10.1 Motherboard Replacement: passo 3, immagine 1 di 3 Samsung Galaxy Tab 10.1 Motherboard Replacement: passo 3, immagine 2 di 3 Samsung Galaxy Tab 10.1 Motherboard Replacement: passo 3, immagine 3 di 3
    • Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel.
    Chiedi a FixBot
    Aggiungi Commento
  4. Samsung Galaxy Tab 10.1 Motherboard Replacement, Battery: passo 4, immagine 1 di 3 Samsung Galaxy Tab 10.1 Motherboard Replacement, Battery: passo 4, immagine 2 di 3 Samsung Galaxy Tab 10.1 Motherboard Replacement, Battery: passo 4, immagine 3 di 3
    • Flip up the retaining flaps on the ZIF connectors that secure the three large ribbon cables.
    • Carefully pull the three ribbon cables from their sockets on the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  5. Samsung Galaxy Tab 10.1 Motherboard Replacement: passo 5, immagine 1 di 2 Samsung Galaxy Tab 10.1 Motherboard Replacement: passo 5, immagine 2 di 2
    • Remove the ten 3 mm Phillips #00 screws surrounding the battery.
    Chiedi a FixBot
    Aggiungi Commento
  6. Samsung Galaxy Tab 10.1 Motherboard Replacement: passo 6, immagine 1 di 3 Samsung Galaxy Tab 10.1 Motherboard Replacement: passo 6, immagine 2 di 3 Samsung Galaxy Tab 10.1 Motherboard Replacement: passo 6, immagine 3 di 3
    • Lift the edge of the battery up with your finger or a spudger.
    • Detach the battery by holding the motherboard down while gently lifting the battery up.
    Chiedi a FixBot
    Aggiungi Commento
  7. Samsung Galaxy Tab 10.1 Motherboard Replacement, Volume and Power Button: passo 7, immagine 1 di 1
    • Hold down the motherboard with your finger and use a spudger to gently pry up the connection for the volume keys and power key.
    Chiedi a FixBot
    Aggiungi Commento
  8. Samsung Galaxy Tab 10.1 Motherboard Replacement, Flash and Rear Camera Connection: passo 8, immagine 1 di 2 Samsung Galaxy Tab 10.1 Motherboard Replacement, Flash and Rear Camera Connection: passo 8, immagine 2 di 2
    • Using the flat end of a spudger, disconnect the black flash cable connector from the motherboard.
    • Disconnect the white rear-facing camera connector.
    Chiedi a FixBot
    Aggiungi Commento
  9. Samsung Galaxy Tab 10.1 Motherboard Replacement, Front Camera, Micro SD card/headphone Connection: passo 9, immagine 1 di 2 Samsung Galaxy Tab 10.1 Motherboard Replacement, Front Camera, Micro SD card/headphone Connection: passo 9, immagine 2 di 2
    • Use the flat end of a spudger to disconnect the orange front-facing camera connector.
    • Disconnect the blue Micro SD card/headphone jack connector from its socket on the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  10. Samsung Galaxy Tab 10.1 Motherboard Replacement, Speakers and Antenna Connection: passo 10, immagine 1 di 3 Samsung Galaxy Tab 10.1 Motherboard Replacement, Speakers and Antenna Connection: passo 10, immagine 2 di 3 Samsung Galaxy Tab 10.1 Motherboard Replacement, Speakers and Antenna Connection: passo 10, immagine 3 di 3
    • Using the flat end of a spudger, disconnect the orange speaker connectors for the left and right speakers.
    • Disconnect the gold antenna cable connector from its socket on the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  11. Samsung Galaxy Tab 10.1 Motherboard Replacement, Motherboard Removal: passo 11, immagine 1 di 2 Samsung Galaxy Tab 10.1 Motherboard Replacement, Motherboard Removal: passo 11, immagine 2 di 2
    • Lifting from the bottom edge, gently remove the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 18 persone hanno completato questa guida.
Davie Sy
Membro da: 09/30/13
1.430 Reputazione
4 guide realizzate
Cal Poly, Team 13-5, Forte Fall 2013 Membro di Cal Poly, Team 13-5, Forte Fall 2013
CPSU-FORTE-F13S13G5
5 Membri
17 guide realizzate
5Commenti sulla guida
Comment passe t'on de l'étape 6 à 7 ? (plastique gris qui fait le tour)
Sebastien Mlakar - Rispondi Condividi
My 10.1 tablet switches on but the only thing showing on the screen is the “Samsung Galaxy 10.1” logo.
If the on/off button is held down for 20 seconds or so the screen goes blank for a few seconds then the logo reappears but nothing else happens. This logo only disappears when the battery is fully discharged.
After re-charging the battery the whole process is repeated
Any suggestions as to the problem
Jim
Jim Smith - Rispondi Condividi
I'm having the same issue
PBRECHEISEN5567 - Rispondi Condividi
have anyone found a solution?
Shaun Smith - Rispondi Condividi
What if I don't have screws on the outside of tablet?
Stacy Moseley - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 8
Ultimi 7 giorni: 34
Ultimi 30 giorni: 111
Tutti i Tempi: 48,702
