Introduzione
In this guide, you will learn how to remove and replace your front facing camera on your Samsung Galaxy Tab 10.1. A broken front camera makes for difficult selfies or video chats. There are a couple of prerequisites to get out of the way first!
Cosa ti serve
Place the bottom of the tablet towards you.
Remove the 4.1mm screws near the charge port with a Tri-Wing screwdriver.
If there are plastic tabs covering these screws, use pointed tweezers to pry the tabs out.
Flip up the retaining flaps on the ZIF connectors that secure the three large ribbon cables.
Carefully pull the three ribbon cables from their sockets on the motherboard.
Use the spudger to pry up on orange connection. This is the connection to the front facing camera.
Altre 3 persone hanno completato questa guida.
