Introduzione
Once the back panel of the device has been removed, replacing the rear camera is very straightforward. Make sure you disconnect the correct cable and you'll be fine!
Cosa ti serve
Screen side facing you, rotate device 180 degrees so the "SAMSUNG" logo is upside down.
Using the plastic opening tool, start in the center near the charge port and wedge the angled tip between the plastic back and the glass screen.
Create a wedge and apply pressure. Use the tool to separate the screen from the back until you hear an audible “pop."
Continue to wedge the tool about every inch along the current edge.
Disconnect the rectangular connection from the rear camera to the motherboard.
A group of five connections are all together. Starting from the left, the fourth connection is the one you want to remove.
Altre 2 persone hanno completato questa guida.
