Salta al contenuto principale
Samsung Galaxy Stardust Battery Replacement
Cosa ti serve
  1. Samsung Galaxy Stardust Battery Replacement, Battery: passo 1, immagine 1 di 2 Samsung Galaxy Stardust Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Hold down the power button located on the right side of the phone.
    • After five seconds, the screen will display three different options. Select the "power off" option.
  2. Samsung Galaxy Stardust Battery Replacement: passo 2, immagine 1 di 3 Samsung Galaxy Stardust Battery Replacement: passo 2, immagine 2 di 3 Samsung Galaxy Stardust Battery Replacement: passo 2, immagine 3 di 3
    • Place your finger or opening tool in the hole on the side of the phone.
    • Carefully pull the back casing away from the phone while keeping the phone stable.
  3. Samsung Galaxy Stardust Battery Replacement: passo 3, immagine 1 di 2 Samsung Galaxy Stardust Battery Replacement: passo 3, immagine 2 di 2
    • Place both the phone and the phone casing next to each other with the battery facing upwards.
    • Carefully lift the battery from the indent above the battery, then place the battery next to the phone.
  4. Samsung Galaxy Stardust Battery Replacement: passo 4, immagine 1 di 3 Samsung Galaxy Stardust Battery Replacement: passo 4, immagine 2 di 3 Samsung Galaxy Stardust Battery Replacement: passo 4, immagine 3 di 3
    • Take your new battery and look for the plus and minus signs on the bottom of the battery.
    • Line up the signs to the three strips on the bottom of the phone.
    • Carefully place the battery in until it is secure inside the phone.
  5. Samsung Galaxy Stardust Battery Replacement: passo 5, immagine 1 di 1
    • Take the back of the phone and line up the circular hole to the camera.
    • Apply force to the back of the phone with your hand, until the back case snaps onto the phone and is secure.
Linea Traguardo
Alan Kwong
Membro da: 03/22/21
121 Reputazione
1 Guida realizzata
2 Commenti
bom dia como concertar o samsung A32
camargowil - Replica
bom dia podem me mandar ,para mim e outros armenque o esquema eletrico do samsung A32=SM-A32 5M/DS
como desmontar e se possivel o esquema eletrico.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 50
Tutti i Tempi: 2,522
