Salta al contenuto principale
Samsung Galaxy Sol Speaker Replacement
Cosa ti serve
  1. Samsung Galaxy Sol Speaker Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
  2. Samsung Galaxy Sol Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the battery by lifting from the bottom up with an opening tool or a small flat tool such as a credit card.
  3. Samsung Galaxy Sol Speaker Replacement, Speaker: passo 3, immagine 1 di 1
    • Remove all ten 0.4mm screws by unscrewing them with the Phillips #00 screwdriver. After this, you will be able to lift up and remove the grey plastic piece.
  4. Samsung Galaxy Sol Speaker Replacement: passo 4, immagine 1 di 1
    • This is the speaker that you will be removing in the next step.
  5. Samsung Galaxy Sol Speaker Replacement: passo 5, immagine 1 di 1
    • Using the curved tweezers, grab ahold of the gold piece of the speakers and slowly lift out of the speaker slot.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 387
