Salta al contenuto principale
Samsung Galaxy Sol Rear Camera Replacement
Cosa ti serve
  1. Samsung Galaxy Sol Rear Camera Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
    Chiedi a FixBot
  2. Samsung Galaxy Sol Rear Camera Replacement: passo 2, immagine 1 di 1
    • Remove the battery by lifting from the bottom up with an opening tool or a small flat tool such as a credit card.
    Chiedi a FixBot
  3. Samsung Galaxy Sol Rear Camera Replacement, Rear Camera: passo 3, immagine 1 di 1
    • Remove the grey back of the phone by unscrewing all ten 0.4mm screws with a Phillips #00 screw bit.
    Chiedi a FixBot
  4. Samsung Galaxy Sol Rear Camera Replacement: passo 4, immagine 1 di 1
    • After you have removed all the screws, take a credit card or plastic tool to lift the screen. You will go all around the border of the phone.
    Chiedi a FixBot
  5. Samsung Galaxy Sol Rear Camera Replacement: passo 5, immagine 1 di 3 Samsung Galaxy Sol Rear Camera Replacement: passo 5, immagine 2 di 3 Samsung Galaxy Sol Rear Camera Replacement: passo 5, immagine 3 di 3
    • After removing the grey part of the phone, you will need to remove the motherboard by detaching all the chips.
    Chiedi a FixBot
  6. Samsung Galaxy Sol Rear Camera Replacement: passo 6, immagine 1 di 1
    • Once you detach the chips, remove the hard drive to access the rear camera.
    Chiedi a FixBot
  7. Samsung Galaxy Sol Rear Camera Replacement: passo 7, immagine 1 di 2 Samsung Galaxy Sol Rear Camera Replacement: passo 7, immagine 2 di 2
    • To remove the rear camera, flip the tab upward and then pull the camera straight out.
    Chiedi a FixBot
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 36
Tutti i Tempi: 711
