Salta al contenuto principale
Samsung Galaxy Sol Headphone Jack Replacement
Cosa ti serve
  1. Samsung Galaxy Sol Headphone Jack Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
  2. Samsung Galaxy Sol Headphone Jack Replacement: passo 2, immagine 1 di 1
    • Remove the battery by lifting from the bottom up with an opening tool or a small flat tool such as a credit card.
  3. Samsung Galaxy Sol Headphone Jack Replacement, Headphone Jack: passo 3, immagine 1 di 1
    • Remove the grey back of the phone by unscrewing all ten 0.4mm screws with a Phillips #00 screw bit.
  4. Samsung Galaxy Sol Headphone Jack Replacement: passo 4, immagine 1 di 1
    • Turn the phone around and remove the screen using the plastic tool.
  5. Samsung Galaxy Sol Headphone Jack Replacement: passo 5, immagine 1 di 1
    • Remove the headphone jack at the top of of the phone by carefully removing it with tweezers.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 335
