Salta al contenuto principale
Samsung Galaxy Sol Front Camera Replacement
Cosa ti serve
  1. Samsung Galaxy Sol Front Camera  Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
  2. Samsung Galaxy Sol Front Camera  Replacement: passo 2, immagine 1 di 1
    • Remove the battery by lifting from the bottom up with an opening tool or a small flat tool such as a credit card.
  3. Samsung Galaxy Sol Front Camera  Replacement, Front Camera: passo 3, immagine 1 di 1
    • Remove all ten 0.4 mm screws with a Phillips #00 screw bit. After this, you will be able to lift up and remove the grey plastic piece.
  4. Samsung Galaxy Sol Front Camera  Replacement: passo 4, immagine 1 di 1
    • Remove the front camera at the top left of the phone be carefully removing it with tweezers.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 8
Tutti i Tempi: 446
