Salta al contenuto principale
Samsung Galaxy SIII Mini VE Battery Replacement
Cosa ti serve
  1. Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: passo 1, immagine 1 di 3 Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: passo 1, immagine 2 di 3 Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: passo 1, immagine 3 di 3
    • Flip the phone over so you are viewing the back.
    • Using you fingernail, or an opening tool, pry open the notch that is located at the top of the phone.
    • Carefully follow you finger or opening tool around the edge of the rear casing until it has detached from the phone.
    • Set the rear casing aside for future use.
  2. Samsung Galaxy SIII Mini VE Battery Replacement, Removing the Battery: passo 2, immagine 1 di 2 Samsung Galaxy SIII Mini VE Battery Replacement, Removing the Battery: passo 2, immagine 2 di 2
    • The battery is the large grey and black rectangle.
    • Using your fingernail, or opening tool, gently pry the bottom of the battery until it pops out.
    • Place the old battery aside for now, or dispose of it properly.
  3. Samsung Galaxy SIII Mini VE Battery Replacement, Inserting New Battery: passo 3, immagine 1 di 2 Samsung Galaxy SIII Mini VE Battery Replacement, Inserting New Battery: passo 3, immagine 2 di 2
    • Locate your new battery.
    • Correctly orient the new battery to be inserted.
    • To orient the battery, make sure the 3 metallic bars align with the 3 prongs on the phone.
    • Gently insert the new battery into the battery slot.
Conclusione
Altre 9 persone hanno completato questa guida.
Megan
Membro da: 10/23/14
1.186 Reputazione
6 Guide realizzate
Michigan Tech, Team 1-8, Lauer Fall 2014 Membro di Michigan Tech, Team 1-8, Lauer Fall 2014
MTU-LAUER-F14S1G8
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 17
Tutti i Tempi: 3,340
