Introduzione
If the touch screen / digitizer / glass or the LCD display is broken, this manual will show you, how to disassemble the phone and replace the Display Assembly without frame.
[text|align=center]
_______________________________________ Video tutorial _______________________________________
Cosa ti serve
Panoramica Video
LCD Display + Touch screen (Display Assemblay) for Samsung Galaxy S III mini / i8190.
Switch off the phone, remove the battery and any SIM and memory card.
Remove 10x Phillips screws.
With a plastic tool remove the Middle frame.
Screw size is PH00, and they're all the same size, so don't worry about getting any of them mixed up! :)
Altre 18 persone hanno completato questa guida.
2 Commenti
Followed the VDO exactly and managed to fix the screen. Getting the right glue for the screen delivered took the longest time.
Worked perfectly, used regular glue I had at home and it worked just fine. Thanks!!
