Salta al contenuto principale
Introduzione
If the touch screen / digitizer / glass or the LCD display is broken, this manual will show you, how to disassemble the phone and replace the Display Assembly without frame.
[text|align=center]
_______________________________________ Video tutorial _______________________________________
Panoramica Video
  1. LCD Display + Touch screen (Display Assemblay) for Samsung Galaxy S III mini / i8190. Switch off the phone, remove the battery and any SIM and memory card.
    • LCD Display + Touch screen (Display Assemblay) for Samsung Galaxy S III mini / i8190.
    • Switch off the phone, remove the battery and any SIM and memory card.
  2. Remove 10x Phillips screws. With a plastic tool remove the Middle frame. With a plastic tool remove the Middle frame.
    • Remove 10x Phillips screws.
    • With a plastic tool remove the Middle frame.
  3. Disconnect: Menu buttons flex cable Micro SD Card reader flex cable
    • Disconnect:
    • Menu buttons flex cable
    • Micro SD Card reader flex cable
    • Lift up slightly the mother board from the right edge.
    • Unstick the Earpiece and Main camera from the display frame. Be careful, don't break flex cables.
    • Now disconnect the LCD Display flex cable which is located on the underside of the board.
  4. Front camera
    • Front camera
    • Main / Rear camera
    • Earpiece
    • Loudspeaker
    • Vibro motor
  5. Batterie per PC portatili
    Batteries for all the top PC brands, backed by our Quality Guarantee.
    Acquista ora
    Acquista ora
  6. Let's test the new spare part. First connect the Display assembly, grab the phone comfortably and then put the battery. First connect the Display assembly, grab the phone comfortably and then put the battery.
    • Let's test the new spare part.
    • First connect the Display assembly, grab the phone comfortably and then put the battery.
  7. Warm the touchscreen to make adhesive tape soft. You can use a hair dryer. If the glass is cracked, put the tape in order not to scatter pieces. Use the front camera hole to separate the glass at the corner.
    • Warm the touchscreen to make adhesive tape soft. You can use a hair dryer.
    • If the glass is cracked, put the tape in order not to scatter pieces.
    • Use the front camera hole to separate the glass at the corner.
    • Continue with separation with plastic tools, from up to down.
  8. Gently separate the menu buttons flex cable from the touchscreen. Gently separate the menu buttons flex cable from the touchscreen. Gently separate the menu buttons flex cable from the touchscreen.
    • Gently separate the menu buttons flex cable from the touchscreen.
  9. If the display is left on the frame, use the same techniques to remove it. If the display is left on the frame, use the same techniques to remove it. If the display is left on the frame, use the same techniques to remove it.
    • If the display is left on the frame, use the same techniques to remove it.
  10. Clean the frame from the remnants of tape and install new. Be careful with the menu buttons and the holes for the camera and the light sensor, don't cover them. Be careful with the menu buttons and the holes for the camera and the light sensor, don't cover them.
    • Clean the frame from the remnants of tape and install new.
    • Be careful with the menu buttons and the holes for the camera and the light sensor, don't cover them.
  11. Will be easier if you use adhesive, ready for the model. Install the new display assembly and start with reassembling. Install the new display assembly and start with reassembling.
    • Will be easier if you use adhesive, ready for the model.
    • Install the new display assembly and start with reassembling.
  12. That's all.
    • That's all.
    • Did you do it successfully?
Conclusione
Altre 17 persone hanno completato questa guida.
ZFix
Membro da: 09/12/2013
165.734 Reputazione
305 Guide realizzate
Master Techs Membro di Master Techs
Community
287 Membri
811 Guide realizzate
Followed the VDO exactly and managed to fix the screen. Getting the right glue for the screen delivered took the longest time.
Erick Ogam - Replica
Worked perfectly, used regular glue I had at home and it worked just fine. Thanks!!
Elisa Díaz Ipes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 73
Tutti i Tempi: 15,866
