Introduzione
We will show you how to fix your phone if you have message "Camera failed".
There are 5 steps to solve this problem.
After each step, check that your camera works.
If not - go to the next step.
________________________ Video tutorial: ________________________
Cosa ti serve
Panoramica Video
Go to:
> Settings
> Application manager
> All
>Camera
Clear data and cache and check that the camera works. If no, go to the next step.
Go to:
> Settings > Backup and reset
> Factory data reset
> Reset device > Erase everithing
For a Hard reset using hardware keys, follow this manual:
Open sammobile and make an registration.
Search the firmware for your model and find the variant, corresponding to your mobile phone.
In the download page you can find instructions and link to the Odin app.
Switch off the phone and remove the battery and any SIM and memory card.
Remove the Midframe.
Disconnect the Menu buttons and the SD card reader flex cables.
Lift the board slightly to the left side and be careful with the earpiece and the main camera - they are stuck to the Display frame.
If the camera still does not work, the last step is camera replacement.
Altre 16 persone hanno completato questa guida.
3 Commenti
how did you do it?!
Haha thanks
