Salta al contenuto principale
Samsung Galaxy SIII Mini Camera Failed Troubleshooting
Cosa ti serve
Panoramica Video
  1. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Data and Cache: passo 1, immagine 1 di 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Data and Cache: passo 1, immagine 2 di 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Data and Cache: passo 1, immagine 3 di 3
    • Go to:
    • > Settings
    • > Application manager
    • > All
    • >Camera
    • Clear data and cache and check that the camera works. If no, go to the next step.
  2. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Factory / Hard Reset: passo 2, immagine 1 di 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Factory / Hard Reset: passo 2, immagine 2 di 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Factory / Hard Reset: passo 2, immagine 3 di 3
    • Go to:
    • > Settings > Backup and reset
    • > Factory data reset
    • > Reset device > Erase everithing
    • !!! This will erase all your data !!!
    • For a Hard reset using hardware keys, follow this manual:
    • Samsung Galaxy - Wipe data/Factory reset
  3. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Firmware: passo 3, immagine 1 di 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Firmware: passo 3, immagine 2 di 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Firmware: passo 3, immagine 3 di 3
    • Open sammobile and make an registration.
    • Search the firmware for your model and find the variant, corresponding to your mobile phone.
    • You can see the variant from Settings > About the device, or from dialer app by entering *#1234#
    • In the download page you can find instructions and link to the Odin app.
  4. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Reconnecting Camera: passo 4, immagine 1 di 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Reconnecting Camera: passo 4, immagine 2 di 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Reconnecting Camera: passo 4, immagine 3 di 3
    • Switch off the phone and remove the battery and any SIM and memory card.
    • Remove the Midframe.
    • Disconnect the Menu buttons and the SD card reader flex cables.
    • Lift the board slightly to the left side and be careful with the earpiece and the main camera - they are stuck to the Display frame.
  5. Samsung Galaxy SIII Mini Camera Failed Troubleshooting: passo 5, immagine 1 di 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting: passo 5, immagine 2 di 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting: passo 5, immagine 3 di 3
    • Disconnect the LCD Display flex cable.
    • Open the camera flex cable connector and reconnect the camera.
  6. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Replacement: passo 6, immagine 1 di 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Replacement: passo 6, immagine 2 di 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Replacement: passo 6, immagine 3 di 3
    • If the camera still does not work, the last step is camera replacement.
  7. Samsung Galaxy SIII Mini Camera Failed Troubleshooting: passo 7, immagine 1 di 1
    • Did you do it successfully?
Conclusione
Altre 16 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.278 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.528 Guide realizzate
3 Commenti
I did it! I did it! I did it!
I save time and money!
Thank you sooooo much!
Batis Kaf - Replica
how did you do it?!
zohny.omar -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 9,550
