Introduzione
The motherboard is the brain of your phone. You may need to replace the motherboard if your phone is having major issues. Before you start, it may be beneficial to check out this troubleshooting page to diagnose your problems.
Be forewarned- if you replace your motherboard, your device will lose its waterproof capabilities. You will need to replace the waterproof seal if you see your device getting wet in the near future.
Cosa ti serve
Before you begin, switch off your phone.
Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
Press a suction cup onto the back cover.
Lift the back cover's bottom edge with your suction cup, opening a slight gap between the back cover and the frame.
Insert an opening pick in the gap you created and slide it to the bottom right corner.
Insert a second opening pick and slide it to the bottom left corner.
Insert a third opening pick to prevent the adhesive from resealing during the rest of the removal procedure.
Altre 16 persone hanno completato questa guida.
3 Commenti
Are there any issues with replacing the motherboard in phone sold for one region, such as the SM-G960U, with the motherboard for a different region, such as the SM-G960F?
Salve. Se non funziona il bluetooth wifi e connessione cellulare. Bisogna sostituire la Scheda madre?
