Introduzione
The charging port in the connection point where the charging cable goes in to feed power to the device. You may want to check our troubleshooting page first to verify that there isn't a problem with the software of the device.
If the problem turns out to be a hard ware problem, then you will have to replace the charging port board on your device.
Be forewarned- replacing this part involves breaking your phone's waterproof seal. If you want your phone to keep its waterproof capabilities, you will have to replace the seal.
Cosa ti serve
Before you begin, switch off your phone.
Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
Press a suction cup onto the back cover.
Lift the back cover's bottom edge with your suction cup, opening a slight gap between the back cover and the frame.
Insert an opening pick in the gap you created and slide it to the bottom right corner.
Insert a second opening pick and slide it to the bottom left corner.
Insert a third opening pick to prevent the adhesive from resealing during the rest of the removal procedure.
Altre 33 persone hanno completato questa guida.
8 Commenti
Hi, does the screen need to be replaced once the charging port has been replaced?
Hi Elliot! If you replace your charging port, you will need to replace the back cover, but the screen should remain intact. It is very difficult to remove the back cover without breaking it (unless you have access to a heat gun), so if you’re thinking about replacing your charging port, you may want to get a new back cover ready beforehand. Good luck and Happy Fixing!
A lot of parts missing to this guide.
Hi there, is there anything you would recommending replacing/updating/upgrading while you have the phone disassembled? Thanks!
This guide is decent, but it was not my primary reference for this task. IMO a better guide can be found here: https://www.youtube.com/watch?v=o1NYvdkZ...
