Salta al contenuto principale
Samsung Galaxy S9 Back Cover Replacement
Guida Archiviata
Questa guida รจ mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. Samsung Galaxy S9 Back Cover Replacement, Back Cover: passo 1, immagine 1 di 1
    • Heat the iOpener in the microwave for 30-60 seconds.
    • Apply the iOpener to the backside edge and let it sit for 2-3 minutes.
  2. Samsung Galaxy S9 Back Cover Replacement: passo 2, immagine 1 di 1
    • Press the suction handle firmly on to the back cover.
    • Insert an opening pick between the back cover and the device's body while pulling upwards on the suction handle.
  3. Samsung Galaxy S9 Back Cover Replacement: passo 3, immagine 1 di 2 Samsung Galaxy S9 Back Cover Replacement: passo 3, immagine 2 di 2
    • Apply more opening picks to the edges of the phone, heating the other sides as needed.
    • Be patient. This step requires quite a bit of work. The adhesive is difficult to melt, making it time-consuming to remove the back of the phone.
    • Because the back panel is made of glass, inserting and sliding the opening picks is likely to crack the glass. If the glass does shatter, please cover it with packing tape to protect your hands from the sharp edges and fragments.
  4. Samsung Galaxy S9 Back Cover Replacement: passo 4, immagine 1 di 3 Samsung Galaxy S9 Back Cover Replacement: passo 4, immagine 2 di 3 Samsung Galaxy S9 Back Cover Replacement: passo 4, immagine 3 di 3
    • Use the iFixit opening tool to separate the back cover from the rest of the device.
  5. Samsung Galaxy S9 Back Cover Replacement: passo 5, immagine 1 di 1
    • Remove the back cover.
Conclusione
Cal Poly, Team S1-G6, White Winter 2019 Membro di Cal Poly, Team S1-G6, White Winter 2019
CPSU-WHITE-W19S1G6
4 Membri
29 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 80
