Salta al contenuto principale
Samsung Galaxy S8 Plus Motherboard Replacement
Cosa ti serve
    • Step by step tutorial about dismantling the logic board from Galaxy S8+. If you need more information ask them in the comments!
    Can you give contact number
    Sandeep - Replica
Conclusione
Altre 6 persone hanno completato questa guida.
Alex Sander
Membro da: 02/28/17
38.219 Reputazione
202 Guide realizzate
3 Commenti
How do you then fix the imei to match the back of the phone and to work with the plan it was on when broken; having to register/activate a new device for a motherboard repair is bull$][!+, and doesn't take care of the problem for the customer.
chrisjwellnitz - Replica
Hello, The connector from the battery to the motherboard has been damaged. Due to water getting in there’s been corrosion on the connectors which has eaten away on 2 of the capacitors there down to the silicon. Is there anyway to fix this? Perhaps any way to add material back or make some kind of jumper? I doubt I can get a replacement motherboard, but if you know if this can be done that would be great.
Ggarcia - Replica
..does this correct a problem with the SIM card holder or is that a separate board in the phone?
Sigmund -
Sigmund - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 48
Tutti i Tempi: 10,896
