Introduzione
Use this guide to remove or replace the NFC antenna and charging coil in your Samsung Galaxy S7.
This guide involves removing the rear glass cover. You will need replacement adhesive to reattach the back cover to the phone.
Cosa ti serve
Apply a heated iOpener to a long edge of the phone for about two minutes.
Remove the eight 3.5 mm Phillips screws securing the NFC antenna and charging coil assembly.
Altre 4 persone hanno completato questa guida.
9 Commenti
this is perfect
Can you help me with videos ?
Does this also replace the charging port itself?
Hi Adam, this guide is not for replacing the charging port—the charging port is part of a separate assembly that requires further disassembly to remove.
