Introduzione
Follow this guide to replace the loudspeaker assembly in a Samsung Galaxy S7 Edge.
Note: The curved edge and strong adhesive make the initial opening procedure very challenging. Be patient, repeat multiple heat and pull cycles, and the adhesive will eventually loosen.
Cosa ti serve
Heat an iOpener and apply it to a long edge of the phone for about two minutes.
Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
Altre 3 persone hanno completato questa guida.
