Salta al contenuto principale
Samsung Galaxy S7 Active Screen Replacement
Cosa ti serve
  1. Samsung Galaxy S7 Active Screen Replacement, Samsung Galaxy S7 Active Disassembly: passo 1, immagine 1 di 1
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Screen Replacement: passo 2, immagine 1 di 1
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Screen Replacement: passo 3, immagine 1 di 2 Samsung Galaxy S7 Active Screen Replacement: passo 3, immagine 2 di 2
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Screen Replacement: passo 4, immagine 1 di 1
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
  5. Samsung Galaxy S7 Active Screen Replacement, Screen: passo 5, immagine 1 di 3 Samsung Galaxy S7 Active Screen Replacement, Screen: passo 5, immagine 2 di 3 Samsung Galaxy S7 Active Screen Replacement, Screen: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use the tweezers to disconnect the screen from the phone by detaching the connection.
  6. Samsung Galaxy S7 Active Screen Replacement: passo 6, immagine 1 di 3 Samsung Galaxy S7 Active Screen Replacement: passo 6, immagine 2 di 3 Samsung Galaxy S7 Active Screen Replacement: passo 6, immagine 3 di 3
    • Clean the rest of the adhesive left on the phone by scraping it off with a metal tool.
    • Apply rubbing alcohol on the adhesive to make sure phone is free of any adhesive. Do this by applying some rubbing alcohol onto a napkin.
    • Lightly proceed to clean the phone with that napkin.
Conclusione
Altre 3 persone hanno completato questa guida.
Erick Vazquez
Membro da: 04/18/18
180 Reputazione
1 Guida realizzata
Cal Poly, Team S18-G1, Livingston Spring 2018 Membro di Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
4 Membri
15 Guide realizzate
3 Commenti
Do you know where i can find a replacement screen assembly, cant find one anywhere
Sam Ellis - Replica
I bought a digitizer with fog and polarizer and a new front glass, it came with the loca. What else do I need to make the complete LCD screen assembly?
Michael Shep - Replica
The instructions are excessively brief. The photos are insufficient to convey the details of this operation. Attempted and damaged my phone.
RAC - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 21
Tutti i Tempi: 9,114
